Forum: Wishes and new features
Topic: 2 small features needed
1. When you drag&drop/'pull fast' at the top 'where the song curves are' that it fades out/in as it does in traktor DJ S. wich makes it easy to mix in a nice and proffesional way...
2. Why are there only 12 samples? it shouldn't be that hard to add more.. just split the height in 2 and have twice as much.. Or maybe have an option where you enter how many samples you want to be using... then it decreases the width depending on how many you choose. and if samples > 12 then you create a new set of rows for them.
I know that you can change while you DJ at a party, but i'd rather concentrate on what songs to do next then finding which sample to load..
hope that i don't ask for much.. hope that you'll add it before i buy it.
greets Dani
geposted Tue 13 Apr 04 @ 12:42 pm
