Hi developers,
Your section has been updated and you'll find a new "mappers" section.
Now you can remap all controlers such as DAC3, DJConsole, ...
Good luck :)
Good luck :)
geposted Mon 21 Nov 05 @ 10:04 am
@ devstaff
Can you also update the Skin Creation Reference page as it is now very outdated & it is very hard to keep track of all the new features & their usage
geposted Mon 21 Nov 05 @ 1:37 pm
Where is this new "Mappers" section?. I see that there is a new Dac-3 mapper in v3.2 but I can't sem to find it anywhere
geposted Mon 21 Nov 05 @ 3:28 pm
Just search on the website, I found it :)
geposted Mon 21 Nov 05 @ 3:50 pm
geposted Mon 21 Nov 05 @ 7:44 pm
ok good
geposted Mon 21 Nov 05 @ 7:50 pm
The dll name for djconsole is: djcmapper.dll ;-)
geposted Mon 21 Nov 05 @ 8:18 pm
I've just tried to compile the DAC-3 SDK using Dev-C++, but I'm having problems with it which are causing VDJ to crash.
In order to get it to successfully compile, I've had to correct a number of problems, particularly typecasting and use of IntToStrRelative with 2nd parameter (String) missing), plus added windows.h to DAC3DefaultMapper.cpp
I've now got a DLL file that I've copied to C:Program FilesVirtualDJdac3mapper.dll, but VDJ crashes when trying to load with this file present. The files that I am using can be viewed at http://www.jcdigita.com/virtualdj/code
How can I resolve this problem and compile a working DLL so that I can start playing around with customising it?
geposted Mon 21 Nov 05 @ 9:54 pm
I got 45 errors when I tried to compile the DAC-3 .cpp and.H files into a .DLL with Dev-C++. I didn't changed anything from the files that I downloaded. I just wanted to test it first and all of these errors came back.
Can someone please tell me what I'm doing wrong so I can make my own .DLL
Thank you
Thank you
geposted Tue 22 Nov 05 @ 12:05 am
When I asked on this forum where the c++ developper are , nobody answered. I'm happy to see there are new people :-)
Sorry jpboggis i can't help you as i don't have a dac3 to test. I will analyse your code later when i get free time
geposted Tue 22 Nov 05 @ 12:12 am
I wouldn't call myself a developer but I'm able to figure most things out sooner or later. Since I have a selfish reason to get the DAC3 controller working (Gigs), I'm putting the time to understand how to make a .DLL. It's seems like we need to become developers for this software to get it to do what we want it to do. I'm fine with that but a little support would be helpful.
geposted Tue 22 Nov 05 @ 12:18 am
Its not like that Bmac16
Its more an open aproach, so that the users CAN make plugins etc of their own choice and needs.
And because we know that they will, we also know what there will be Dac3 and Console dlls made real soon...
I really think its a nice way of the software to go, to have an open SDK for users, to develop plugins of choice and need...
geposted Tue 22 Nov 05 @ 8:52 am
Exactly Dj-in-norway
It's great when you know programming. You are really free and you can add powerful tools to VDJ
Besides I'm working on the DJ Control MP3 Mapper. I haven't finished but it already works with a few items
geposted Tue 22 Nov 05 @ 9:27 am
I have just uploaded my source code for dj console1 and dj control mp3 mapper
http://www.virtualdj.com/addons/view.html?type=sound%20effect%20source%20code
For mk2, you have to add the lines for mk2
geposted Fri 25 Nov 05 @ 8:47 pm
For some reason the first SendAction I send seems to get ignored in my MK2 Mapper. For instance load VDJ, load a track and press play play on the MK2 and nothing happens. Press it again and it plays perfectly. The OnButton event is definately called and OnTimer events are getting triggered too.
Any idea why this would happen?
S1GUE
S1GUE
geposted Mon 28 Nov 05 @ 3:03 pm
The minimal source code for the DJC MAPPER is (.cpp) :
#define WIN32_LEAN_AND_MEAN
#include < windows.h>
#include "DJCMapper.h"
class CDJCMapper : public IDJCMapper
public:
HRESULT OnButton(int chan,int button,int down);
HRESULT OnSlider(int chan,int slider,int value,int delta);
HRESULT OnTimer();
ULONG Release();
HRESULT __stdcall DllGetClassObject(const GUID &rclsid,const GUID &riid,void** ppObject)
if(memcmp(&riid,&IID_IVdjDjc,sizeof(GUID))!=0) return CLASS_E_CLASSNOTAVAILABLE;
*ppObject=new CDJCMapper();
return NO_ERROR;
HRESULT CDJCMapper::OnButton(int chan,int button,int down)
return S_OK;
HRESULT CDJCMapper::OnSlider(int chan,int slider,int value,int delta)
return S_OK;
HRESULT CDJCMapper::OnTimer()
return S_OK;
ULONG CDJCMapper::Release()
delete this;
return 0;
public:
HRESULT OnTimer();
ULONG Release();
return NO_ERROR;
return S_OK;
return S_OK;
return S_OK;
delete this;
return 0;
geposted Sun 01 Jan 06 @ 1:43 am
