Forum: VirtualDJ Skins
Topic: Waiting MIX station SV_04 (1024x768) VDJ 3.2
Dear Serge6037 and other guys
I'm waiting the new skin for version 3.2 and I like a lot your skin (the best), can you please insert some new button for the hercules DJ console?
For example 1 botton to have nudge or scratch with jog wheels near the Addition VTC and BPM buttons of the last version.
Please invert the button 1-2-3 to 3-2-1 for the FX in the left deck, in the console is 3-2-1 for left and 1-2-3 for right.
Please insert the new crosfader curve, scratch.
Make a new color for automatic mixing active (right click on automix button), I can only see into the playlist area with the circle around the star.
thanks in advance
geposted Tue 22 Nov 05 @ 12:27 pm
I would also like to see an update for the 'no decks' styled skin and a 'wide' screen version.
Thank you.
I like this skin, and look forward to any update.
Don't worry gee's, Serge6037 keeps up the good work!!
Be patient.
ƒяμﺄτ
OK, I can only wait, but please make the modify for new dj console, a lot of guys buy the new console but there is no skin for it.
There is some news???
The Mix Station is the top download skin and no update, why?
v3.3 updated
Thanks Serge
PS @Serge: i have modified the icons menu in the black skin to make it clean
Just downloded. I have been waiting for this. Thank you for all your hard work. The fact that you and others do this for free, is remarkable.
Hi..
Great skin the Waiting MIX station SV_04, how view the video 1 and 2 source in a different windows? And of course the mix (1+2) window. I use a 1440X900 laptop, why not try to designe a widescreen skin with that screen dimensions? I hope something makes a new version with the right propertyes for me (and for the others have the same problem).
Thanks to all from Italy.
Archi
