Hi, Im trying to configure my trigger finger to work with the new version. Finally they allow the sliders to be used! :) anyways, Does anyone know how to set it up for an effect with more than one slider to be programed? Under the keyboard shortcuts there isn't a way to designate which slider you are configuring, only the deck. Is this not possible yet? Im trying to use it with the echo out effect which has 3 sliders. Any help would be appreciated. Thanks.
geposted Tue 22 Nov 05 @ 7:21 pm
can you map effect paramaters to midi/kb shortcuts?
geposted Wed 23 Nov 05 @ 1:00 am
yes
geposted Wed 23 Nov 05 @ 2:01 am
Well with the keyboard it works well with the 5 sliders but in midi there is still a bug to correct for 2nd to 5th slider.
For the keyboard use the formula given in the help inside vdj to calculate the value to write (you can use absolute or relative [with +and -] as explained)
geposted Wed 23 Nov 05 @ 11:12 am
