Are there any shortcuts for EQ kills? Unless I didn't search thoroughly, I didn't see any in the shortcut tab. Would this be skin-specific?
geposted Wed 23 Nov 05 @ 12:08 pm
in shortcuts
equalizers >> kill_bass (or kill_high / kill_medium) >> choose deck & asign to a key ;)
geposted Wed 23 Nov 05 @ 1:08 pm
Alternatively, if you are mapping to a dial or slider, then I would suggest trying 'bassfader' 'mediumfader' and 'highfader' shortcuts to be able to fade the frequency range between decks with a single set of shortcuts. Of course with that, you couldn't kill the bass on both decks simultaneously for example.
geposted Wed 23 Nov 05 @ 9:49 pm
Thanks. I'll give those a shot.
geposted Thu 24 Nov 05 @ 1:40 am
