Hello,
I found a bug in the skin engine. You can see it if you do the following things:
- choose an mp3 were the automix function will put a cue point just AT THE BEGINNING of the song (important!)
- right click on automix to activate auomix to activate it
- rigth click on automix again to deactivate it
- now minimize vdj by clicking on minimize button
- maximize it again by clicking on the taskbar
Now you will see a rest of the cue mark that should not be there at the left side of the sonposition bar!
It will not go away until you restart vdj or reload the skin.
geposted Thu 24 Nov 05 @ 7:16 pm
https://virtualdj.com/forums/42939/Software_Technical_Support/MK2_Won_t_Cue_After_Upgrade_To_3_2.html
I think it's bug of the version 3.2
geposted Fri 25 Nov 05 @ 12:31 pm
i have noticed this there before, it is the same if you use anchors to BPM a song i think
geposted Mon 28 Nov 05 @ 4:12 am
This is not a bug of the 3.2 version because I found it in 3.1.
I don't have problems with cue points.
The problem is in the skin engine. Only an optical problem. Everything works for me but in some skins this bug looks very ugly, so it would be cool to be fixed. (Sorry for my english.)
geposted Tue 29 Nov 05 @ 9:36 pm
