i just got this yesterday and it work fine now i'm trying to play it today and i keep getting error message each time i click on it
invalid skin file error line %1 in the xml
how can i fix this thanks
geposted Tue 01 Jul 03 @ 11:26 pm
i don't have this prog yet, but if i had this kind of problem, i would try either 1) backup vdj dir and get other skin from here and replace default skin file with it 2) or uninstall the program and possibly delete registy entries and then install again
good luck if you choose to try these (if you didnt understand entirely, i suggest to wait for better help)
geposted Tue 01 Jul 03 @ 11:35 pm
Try re installing . Sounds like a corrupt skin file.
geposted Wed 02 Jul 03 @ 12:52 am
Just a precision! Atomix skin don't work with Virtual DJ.
But this night, I'll make a post to explain how change *.xml skin atomix files to work with VDJ.
See "Skin" section
Gwenn.
See "Skin" section
Gwenn.
geposted Wed 02 Jul 03 @ 6:26 pm
OK Great !
geposted Wed 02 Jul 03 @ 11:18 pm
