As everyone knows that Maya44Usb is out of stock!
Now what'll be the best replacement?
Dj's suggested me to go for Delta44 or 66 to connect 2 TCVs with VDJ.
Give me your suggestions.
geposted Tue 29 Nov 05 @ 11:57 am
Hercules MK2 midi controller, with excellent soundcard, and 2x line in (asio) for timecode
thats my choice at least :)
geposted Tue 29 Nov 05 @ 5:57 pm
which excellent soundcard your talking about...name 1 atleast.
geposted Tue 29 Nov 05 @ 10:54 pm
The Hercules DJ Console has a built in soundcard which supports ASIO very well.
If your looking for another good soundcard I would recommend the M-Audio Delta 44 or Delta-66.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Wed 30 Nov 05 @ 12:10 am
i'd say the delta 44 is the cheaper of choices but with the mk2 you certainly can use the buttons to control also.
geposted Wed 30 Nov 05 @ 12:50 am
[[[There are negative responses from some djs over Hercules Dj console]]]
read them here-->
http://www.musiciansfriend.com/srs7/g=dj/product/reviews/base_pid=633250/rpp=10/
Hercules Dj Console:
-ve
1) Bad latency
+ve
1) Compact & portable
Delta 44/66 is the best solution for TCVs,
even more powerfull & stable than Maya44Usb
How can u rely on such a compact thing like Hercules dj console with so many functions already built-in.
H-DJ_C is un-stable & un-reliable product.
Hercules dj console is indeed the BEST for beginners, & Worse for Pro djs.
It looks cool, attractive & hands-on ready, for young enthusiasts to get the action on!
A key function of a professional product's circuit is always dedicated to 1 particular thing, & is'nt designed multi-dimensional.
read them here-->
-ve
1) Bad latency
+ve
geposted Wed 30 Nov 05 @ 9:10 am
If you have a desktop computer then your best choice is the M-Audio Delta 44 PCI (or 66 too). If you like to have a controller to control VDJ the DJConsole MK2 is the choice with his 2 built in USB soundcards.
The review in Musicians Friend were for the DJConsole not for the MK2 model.
http://us.hercules.com/products/showpage.php?p=110&b=1&f=1
geposted Thu 01 Dec 05 @ 2:55 am
Umm I dont know as a pro user if I would want to buy the MK2 is that the only choice out there for campatable Laptop sound cards
geposted Wed 28 Dec 05 @ 4:54 pm
