Forum: Wishes and new features
Topic: add events to cues - Page: 1
I don't know how feasible this would be, but it would be extremely useful.
Would it be possible to add events to cues? Just like having VDJ automatically perform a keyboard shortcut at exactly the right time. It would be great for making remixes or editing songs. That way instead of recording it several times before you get it *just right* you can just set up cues for all your actions and have VDJ do it perfectly. I don't think this would be too hard to impliment.
geposted Tue 29 Nov 05 @ 7:37 pm
also you can send DMX signals then, so for each song you can have specified lightshow :-)
but this will be nicer probably with separate lightcues maybe on separate progress bar
geposted Tue 29 Nov 05 @ 9:07 pm
Yeah, wouldn't it be great? And I don't imagine it would be too hard, because there is already the ability to do almost anything with keyboard shortcuts.
geposted Tue 29 Nov 05 @ 11:35 pm
Lopez453:
This idea was posted some time ago, see here:
http://www.virtualdj.com/forums/6171/New_features/Lighting_controller.html
You could use the same wave window, but give the "light points" just another color as the cue points. I would have liked that implementation better, over the current implementation.
At this moment you only have limited options. When you could connect to eg Sunlite or light jockey, you could let a LJ do a manual light show. If you have set "light points" the light jock could choose to use these instead.
Ewout
geposted Wed 30 Nov 05 @ 10:51 pm
geposted Sat 10 Dec 05 @ 3:53 am
Sorry I didn't see that before. It's a great idea though, and probably not difficult to implement. Hopefully enough people will like this idea that the team will take notice.
geposted Sat 10 Dec 05 @ 3:57 am
djbambiPRO InfinityMember since 2003
I VOTE FOR!!! big time!!! I want it I want it I want it!!!
I think of all precedent requests, this one has the most explicit/generic title and references the two other ones, so I vote for it here :)
Main reasons why I'd like this feature:
- add a "skip n beats" event to a cue point right before a cheesy break
- add a "loop n beats" even to a cue point towards the end of shorter tracks
Of course, there should also be "enable_cue_events" and "disable_cue_events" actions so that you could turn the feature on/off at the touch of a button.
geposted Sat 10 Dec 05 @ 11:20 am
of course, those "actions on cue" should be saved to the VirtualDJ database.xml file along with the cue info for each track [ Cue Num="0" Name="Cue 1" Pos="22624" action="skip_beat" value="32"]
geposted Sat 10 Dec 05 @ 11:52 am
I vote for ;)
geposted Sat 10 Dec 05 @ 12:11 pm
claxPRO InfinityMember since 2004
One more.
geposted Sat 10 Dec 05 @ 1:21 pm
JeremKPRO InfinityStaffMember since 2004
+1 It's a very good idea.
geposted Sat 10 Dec 05 @ 1:47 pm
one more!!
Really good idea!
Body-Blown
geposted Sun 11 Dec 05 @ 12:35 pm
In combination with the following request, also the colored "Cue" points are solved:
http://www.virtualdj.com/forums/1878/New_features/Cue_points_in_different_colors.html
For lighting actions could be inserted like:
[Cue Num="0" Name="Start Red Beams" Color="Blue" Pos="22624" action="Sunlite Load Cue" value="Red beams moving in circles"]
to send a message to your Sunlite PC (by tcp/ip netwoking?) to load the Cue with the name "Red beams moving in circles". Color in the wave display in VDJ = Blue
Other actions could be "Load Sequence" and "Load Show". Sunlite could be replaced by something like MLJ (Martin light jockey) Or ISC for Innovative show controls (http://www.innovateshowcontrols.com). Last one has a developers Api to control the light software from other software already.
Ewout
geposted Sun 11 Dec 05 @ 3:13 pm
acw_djPRO InfinitySenior staffMember since 2005
Good Superstorm!,
I whish I could prove it...
geposted Wed 14 Dec 05 @ 12:12 am
acw_dj,
I don't understand what you mean.
Ewout
geposted Wed 14 Dec 05 @ 8:28 pm
I would also like to see VDJ tied in with X1 Control Software with the possibilitie to attach a light show to a song using the API.
Ross.
geposted Sun 18 Dec 05 @ 11:03 pm
Don't forget, we're not just talking about light show events here. I'm talking about anything you can do with a keyboard shortcut.
geposted Sun 18 Dec 05 @ 11:35 pm
"ACTION on cue" seems like a VERY good idea ;)
There are MANY possibilities to that it seems :) cool
geposted Mon 19 Dec 05 @ 1:37 am
Yes yes yes! And I really think the dev team can easily add it into the next version of VDJ. I really want this, who else does?
geposted Mon 19 Dec 05 @ 1:40 am
djcelPRO InfinityModeratorMember since 2004
I'm going to start a plugin for this as i have just finished the djcmapper v2.0
geposted Tue 20 Dec 05 @ 6:08 pm
61%
