Thank you for the re-download on my Laptop!
But now I have another concern...
How can I transfer my saved \"Playlist\" from Windows Media Player to the VDJ Playlist?
Does the playlist file in WMP need to be changed to another format? If so, how is this done?
Also, does VDJ have a \"Drag and Drop\" option?
Can I make a back-up copy in case my Laptop crashes or do I have to do a Re-download?
I\'ve looked at FAQ for these ansewers but haven\'t found any.
Thank-You for your time and help.
~joe
~joe
geposted Tue 29 Nov 05 @ 7:47 pm
If you specify a location for the save in a convenient place for vdj to locate it will make it alot easier. I'm not too sure where the default save location is for wmp but you can always save the location to somewhere like my documents. Make sure you change the playlist type to .m3u so vdj can access it.
From vdj you can access the the playlist by scrolling through the tree directory to the location of the playlist. A simpler way is to set your playlist folder as a favorite and then you will access the playlists easy as double clicking on them.
Hope this helps :)
Hope this helps :)
geposted Tue 29 Nov 05 @ 10:45 pm
