So what computer case do you all use? Is it 2u, 3u???? Also please post the link to the site where it can be found! I am looking for a god one. I use a 4u case from Newegg but I am looking for soemthing smaller.
http://www.newegg.com/Product/Product.asp?Item=N82E16811127011
geposted Sat 03 Dec 05 @ 10:06 am
http://www.elektronix.se/Produkter/Industri_PC_CPU_Kort/Industri-PC/Rackmonterbar_/3509
Has been on my eyes for some time.. It has "half" depth compared to 95% of all rackmounts, thus makes it possible to fit in a nice flight case.
Can also be found here (US): http://www.icpamerica.com/products/chassis/rackmount/RACK_3400.html
geposted Sat 03 Dec 05 @ 1:07 pm
Mixmasterboy,
Only take care of the type of PC you're going to put in the case, because you need a proper ventilation (Fans and design) to get all your system in a low temperature.
Your current option looks fine. I think the 300Watts Power Supply is less than you need, change it for a 450 Watts Power Supply at least.
Good Luck!
Good Luck!
geposted Sat 03 Dec 05 @ 5:21 pm
geposted Sat 03 Dec 05 @ 9:03 pm
