im very new to this and was wondering if this mixer is compatable with this program any advice wld be greatly appreciated thanks ;)
geposted Sun 04 Dec 05 @ 8:12 pm
VirtualDJ is compatible with every mixer with 2 stereo inputs in it. The Numark 950USB let you work without buying and extra soundcard.
If you plan to use TCVs or TCCDs then you need and ASIO soundcard (M-Audio PCI Delta 44 for example) to get the connections you need to works with this.
Of Course the first thing to do is to buy VirtualDJ and get all the proper operation of VDJ and full access to samples, effects and other stuff that are only available to register FULL users.
Good Luck!
geposted Thu 08 Dec 05 @ 1:29 am
I have the Numark950 USB, trying to use it for doing my podcast, so far i have not been lucky. What is a TCV or TCCD? Thats a tearm that is lost on me.
Thanks!
tempus
Thanks!
tempus
geposted Thu 07 Sep 06 @ 11:33 pm
