Is there a way of making a karaoke book or list of files that I can print from VDJ or my computer?
Jeff
Jeff
geposted Mon 05 Dec 05 @ 5:36 pm
Some people may talk to you about the database for Virtual DJ, but I don't think it is set up the way you'd want.
I use a couple differnet programs depending on what I'm doing. Keep in mind that my files are all named using "MP3+G Toolz" you can google it. You need to have .Net installed on your PC, but it will go search www.kjpro.com for the correct file name if you used their numbering system.... SC for sound choice, TU for Top Tunes, PHM for Pop Hits Monthly Pop, etc... once you know this, you will end up with files that are as close to correct.
Next thing I use is WinDirLister, google this too. From this I can create a TXT file or a CSV that will open in EXCEL, then it is just getting it into columns.
There are other software packages out there specifically for making books. If you have office, you've got most the tools you'd need anyway.
The nice thing about WinDirLister is that you can also list your Music and Video files if you needed to look through them AND know where they are on your HDD.
Hope that helps. I do books 3 or 4 times a year and I have over 30,000 songs and adding constantly. I'm working on a better solution than PAPER books.
geposted Tue 06 Dec 05 @ 12:45 am
I will check that stuff out
What is the Database?
All I need is the artist and song title for people to look through. I will use the search to find them for myself
THanks
Jeff
THanks
Jeff
geposted Tue 06 Dec 05 @ 6:23 am
I believe the database is an XML file. I don't know much about those, so the gurus here will have to tell you if you can use that.
There's a file in your folder called database there is also an mp3database.txt file in mine.
geposted Fri 09 Dec 05 @ 1:47 pm
