ok so weve all seen it but was it using TCV or that device you can see on the edge of the disk? this has been mentioned before
geposted Wed 07 Dec 05 @ 2:02 am
It isn't used it is up and it's off too... or did you see the light?
geposted Sat 10 Dec 05 @ 2:39 am
what light? i dont know how it works but someone said it isnt a demonstration of the TCV cause its that being used not the TCV. not exaqctly sure how it integrates with vdj but it has been mentioned
geposted Sat 10 Dec 05 @ 2:55 am
the device on TTs is a TTm1 by tascam, its a little device that has a wheel that set on your record. it is used to scratch cds. and i dont know of anyway to use it with VDJ. in the video the device isnt placed on the record so its not in use. :)
geposted Sat 10 Dec 05 @ 5:59 am
Dj Xeo,
You can look how it works here: http://www.tascamdj.com/index.html
As I said before, the TTm1 by Tascam was not used for the TCVs demostration.
geposted Sun 11 Dec 05 @ 8:11 pm
