would it be possible to make a function so that you could have just one button that would scroll through you cue points rather then have one button for each one?
geposted Fri 09 Dec 05 @ 2:59 pm
it's already done :)
the "stop" action scrolls through cue points (begin of track, cue point 1, 2, 3..., begin of track, cue point 1, 2, 3...)
geposted Fri 09 Dec 05 @ 4:00 pm
not sure what you mean "stop action" as in stop button? I really don't want the track "stop" but just access/jump to the cue (1,2,3,etc.) with the same button, because i would be holding the TCV with my finger and would not want to have to press play to start the track again if that function would cause a stop in playing. I would like to make a shortcut for that function, also could that be assigned as a button on a skin?
geposted Fri 09 Dec 05 @ 4:21 pm
oh ok, I misunderstood (didn't picture this in a TCV environment). The stop button does jump through the cue points, but only when the track is stopped. Unfortunately, I don't think a "goto_next_cue" action exists (as far as I know, all assignable functions are listed in http://www.virtualdj.com/support/developers/skin.html).
geposted Fri 09 Dec 05 @ 10:27 pm
well whats the problem with having separate cue buttons and pressing the one you want to go to? have you run out of buttons or soemthing?
geposted Sat 10 Dec 05 @ 2:21 am
well if i had 2 songs with 5 cues i would need 10 buttons, instead i can just tap the same button a couple times and get my cue without the fuss of making sure my finger hits the right button, it just would make for a more simple interface for me, and besides i have crazy amount of shortcuts as it is i dont need like 8-10 more for cues, a keyboard can only take so much.
geposted Sat 10 Dec 05 @ 3:03 am
I guess that could be useful when using TCV, so I tried making a shortcut for go_to_cue +1, and one for -1, thinking that logically, this mightd scroll through, but it didn't; +1 just acts like 1 and -1 didn't do anything.
If the dev team wants to implement a feature like this, I would suggest a memory location initialized to zero that stores the number of the last accessed cue point number so then a +1 or -1 could be added to this to effectively scroll through the cue points. Then an infinite MIDI dial, a MIDI pitch bender or just a pair of buttons (MIDI or keyboard) could be mapped for use as a cuepoint scroll.
geposted Wed 14 Dec 05 @ 3:37 pm
thing is the value is stored as an integer not a string so 1 is the same as positive one. it wouldnt hurt but but personaly i dont see the point. mabey if you have a controller with a limited number of buttons together for cues and you want to ahve alot of cues this could be useful.
geposted Wed 14 Dec 05 @ 7:48 pm
The stored integer is added to the +1 or -1 or else changed if unsigned. This way, if memory contains a zero and you hit the +1 shortcut, the resulting cue point is "1", which would be accessed and then the integer stored. Likewise, if the stored integer is 5 and you hit the shortcut for '-1' then the resulting cue point is "4", which would be accessed in the player and then stored for later use if necessary. However, if a shortcut for an absolute (unsigned) cue is hit, such as "3", then regardless of what is stored, cue point 3 is accessed in the player, and "3" is stored.
I personally don't think I would find this useful for my style, but I am just suggesting a way to easily implement listen2's request.
geposted Thu 15 Dec 05 @ 3:39 pm
well i certainly thank you for spelling out a way that this might be implemented, I just thought that its easier to use less buttons and keep this a little more simple (personally) since i already have tons of shortcuts, most are there just to be able to use VDJ without any controller(backup). There's probably not one user in here with the same set shortcuts anyways so ideas are always different.
geposted Thu 15 Dec 05 @ 4:49 pm
thing is using the same variable for both accessing a specific cue and as a modifier to someting (are you sugesting a variable to be kept for the last cue accessed or what?) is impossible when the datum is simply a signed integer as there is no way to differentiate between say a 1 and a +1. (no way to say differently 'go cue 1' and 'go to next cue')
geposted Sat 17 Dec 05 @ 2:58 am
