Whenever I load songs and catching the cue the point, the tunes tend to jump and get distorted in the other deck, Is this a hardware or software issue???
I'm using two soundcards--1.Creative Labs/2.Generic
2.4GHz
512DDR
(2) 80GB HDD
Windows XP Professional
2.4GHz
512DDR
(2) 80GB HDD
geposted Fri 09 Dec 05 @ 3:38 pm
what version are you using ?
two soundcards are not supported in the demo...
any cracked version are likely to have huge bugs as they are often demo version that have code changed... and therefore not working like it should
geposted Fri 09 Dec 05 @ 3:42 pm
And if you buy your license you could alse get working all your setup with only the Creative Sound Card (If it is a 4.1 or better).
Hope see you soon as a Full Member.
geposted Sat 10 Dec 05 @ 2:12 am
