hello, just wondering if i could my numark axis 2 with vdj, for example use my turntable cd to scratch with vdj, will it play the song and scratch. Thanks
geposted Fri 09 Dec 05 @ 9:47 pm
izzy83,
You can use TCCDs and your current Numark AXIS 2 Tabletop CD Players with VirtualDJ. Of Course, you need the purchased version to work with it.
http://www.virtualdj.com/purchase/index.html
The Demo Don't will let you work with it (only works with one TCCD) and other version are very buggy.
Good Luck!
Good Luck!
geposted Sun 11 Dec 05 @ 1:54 pm
