Forum: Old versions
Topic: Problem with Wavelab 4.0
Hello,
Did anybody ever had a problem with this software after installing Virtual DJ?
I have the DJ Console version (latest update), and after having installed the soft, some files (MP3 format) that were done with Wavelab cannot be opened anymore (some error about the the channel and resolution not being the same).
The files can play correctly in Winamp and WMP (and Virtual DJ !!).
I've check the files properties and everything else seems fine.
What could it be? Anybody has an idea?
I' haven't seen anything on Wavelab site so far about this
Thanks
geposted Mon 19 Apr 04 @ 1:53 pm
try to review the file's properties when saving in Wavelab.
use common setting like WAV or MP3 format 2 channels stereo at 44.1 khz (bitrate 160 or 192 kbs if using mp3)
it has something to do with the format you are using for sure ;)
Found it.
It was a known problem with Wavelab (they got a fix for it). The installation of other things may have triggered the problem.
Thanks anyway.
I Have the same problem please gives me a solution!!!!!!
