I was DJ'ing Friday night, and I have never had this problem before until I downloaded 3.2. Im not sure what the problem was, but my headphones kept shutting off, which is most likely my soundcard that was affected. This was very aggravating cause I had to dj the entire night just swapping songs. I could get them to work if I restart VDJ, but then after a few songs, they would lose sound again. Anyone have any ideas what this could be? I have also been reading up on the forums, but all of my mp3s were skipping all night long. Like I said, I havent had any problems with previous versions, this all started when I downloded 3.2
Please Help, I have 6 more gigs coming up within the next month, I have to get this problem fixed.
Thanks.
Thanks.
geposted Tue 13 Dec 05 @ 6:18 pm
Try using Reactivity in Medium. (VDJ->Config->General->Reactivity). If not, try a fresh install of VDJ 3.2 after you made a backup of your VirtualDJ files.
geposted Tue 13 Dec 05 @ 11:09 pm
i'm still waiting for my maya44 card
in the meantime, i mix by matching the timeline beats
i can vut if i want to, but i use shift +B to mix withouit headphones
just make sure you know the song and cue points if it happens again
geposted Sun 18 Dec 05 @ 9:30 am
