I am taking rick's advice and buying this 3u case.
http://www.servercase.com/miva/miva?/Merchant2/merchant.mv+Screen=PROD&Store_Code=SC&Product_Code=CK350&Category_Code=3U
However, I have no idea what to pick for what kind of mb do you use.
The choices are:
MB using 20pin +4 pin
MB using 24 pin +8pin +4pin
Tyan Dual... (all the options are on that link).
Here is the motherboard I bought for it (ABIT AN8 Socket 939 NVIDIA nForce4 ATX AMD Motherboard).
http://www.newegg.com/Product/Product.asp?Item=N82E16813127197
Please help THANKS!!!
The choices are:
geposted Thu 15 Dec 05 @ 2:14 am
mixmastertoy,
The number of pins is for the power supply you are going to need. The A-Bit you are going to use is a 24 pin adaptor.
You may choose MB using 24 pin +8pin +4pin
geposted Thu 15 Dec 05 @ 4:26 am
