Forum: Old versions
Topic: Reverse Crossfader/Hamster Switch
is it possible to reverse the crossfader on VirtualDJ ?
a hamster switch as it's known on scratch mixers
a technique used by a lot of scratch DJs
any thoughts would be appreciated
thanks
[echorec]
geposted Tue 20 Apr 04 @ 8:47 pm
This is a question for the skinners I belive. I am sure its probably possible.
i'm currious, why would you reverse the crossfader????????
some DJs find it better for scratching - especially if you are right handed
"Hamster Switch - Changes the way the crossfader operates - puts channel 2 on the left side, and channel one on the right - useful to a scratch DJ for various effects. Named after DJ Hamster who invented it."
so there you go !!!
[echorec]
How can I change my crossfader style?
Im using Viryurl DJ pro 7.0
If you register your pro version in your profile, you could download a tool that could change the cf direction aka hamster.
