Hi,
One of the jog wheels on my console has literally fallen off! It has been getting lose for a while now and to day it actually came off!! When I went to put it back on the little rotary spindle thng that it sits into came out of its hole and is now ratteling around inside the console!!! I'm very anoyed about this! The other jog wheel seems to be comming pretty close to it to!
o this
Also some of the buttons are starting to malfunction on it to!! It hasnt even been 2 months yets scince I purchased it off Dolphinmusic.co.uk!
What am I suppposed to do? Is it under warranty etc? I have to put everything on hold now becasue of this! I just order a mixer to go with it yesterday and I was going to buying the full version of VDJ in the next week or so!
Please support team help me!!! Has anyone else here had a simialar experience to this?
Thanks,
Rory
o this
Thanks,
Rory
geposted Fri 16 Dec 05 @ 2:21 am
try to contact dolphinmusic.com so see if they will ship it back or replace it for you since its only been 2 months since you have it.
Many stores that sell DJ software will gladly replace the item if its within warranty period.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Fri 16 Dec 05 @ 2:29 am
Thanks, I'll give it a try.
Rory
Rory
geposted Fri 16 Dec 05 @ 2:38 am
