For those of you using the DAC 3 with VDJ 3.2
Please tell me if it's as easy as dropping in a new mapper into the VDJ 3.2 (as in DAC 2)?
or is it a complicated process?
What I like about the DAC-2 was the simplicity of using the mapper and instructions on which keys to press. Very easy.
Please tell me what I need to know before I order a new DAC 3.
Thanks.
The Premier DJ
Jose
Thanks.
The Premier DJ
Jose
geposted Fri 16 Dec 05 @ 5:14 pm
Anyone!
PLEASE!
What I'm looking for is a mapper (similar to the Dac -2 dmc1mapper.dll mapper that I downloaded from virtualdj.com.) You put this file into the virtualdj folder and something majical happens. The DAC 2 now has different key assignments. Then the author included what keys did what. GREAT GIFT.
I know that someone has either developed one or is in the process.
I'd appreciate the input.
Jose
PLEASE!
Jose
geposted Sat 17 Dec 05 @ 2:39 pm
I FOUND ONE.
http://www.virtualdj.com/blog/jpboggis/
Thanks JP!
Jose
Thanks JP!
Jose
geposted Sat 17 Dec 05 @ 4:18 pm
v1.0 of my DAC-3 mapper has now been released. It should be available via the downloads section of this site shortly.
geposted Sat 17 Dec 05 @ 6:51 pm
jpboggis,
Cool to have this DAC-3 mapper also. Any reviews?
Good Work
Good Work
geposted Mon 19 Dec 05 @ 2:30 pm
