Forum: Old versions
Topic: Equilizer settings
Hi all
I have just purchased Virtual DJ software and I have a question:
How do you stop the EQ settings (The knobs on screen) from setting back to the default eveytime you select a new mp3.
I get it just how I like it and then every time I select another mp3 file it defaults back
thanks!
geposted Fri 16 Dec 05 @ 5:22 pm
if you purchased VDJ don't forget to enter your serial number in your profile: https://virtualdj.com/fusers/modifuser.html
in fame settings of VDJ, you must have Auto-EQ reset activated. desactivate it, this will solve your problem.
