heres what i would like to be able to do:
i am playing a track on deck 1 and have three samples going at the same time, as the song playing on deck 1 is coming up to a break i want to be able to cut all three samples at the same time ie:
with a keyboard shortcut is this possible?
and if so how?
if anyone could help i would sure appreciate it
thnx,
jrmc.
and if so how?
thnx,
jrmc.
geposted Sat 17 Dec 05 @ 7:38 am
Yes you can create a shortcut for many actions.
geposted Sat 17 Dec 05 @ 8:11 am
in shortcuts :
sample >> sample_volume_1 >> value 0
asing to a key that is not in use.
Do the same for all the other (1-12), and asign ALL to the SAME key.
this will mute all samples when the key is pressed :)
geposted Sat 17 Dec 05 @ 5:58 pm
Even better would maybe be like I do...if you have an EXTERNAL mixer.
You connect deck 1 & 2, to channel 1 & 2 at your mixer, and all samples to channel 3 at mixer.
Then, I have a fade slider at my external mixer, to lower volume of all samples, say in song breaks....
geposted Sat 17 Dec 05 @ 6:01 pm
