Hello
I downloaded the trial version yesterday (version 3.2) an I put it to the test. It looks very good exept for the time indications, if you pith up the remaining time stretches instead of diminishing.
My question, is it normal when you put vdj to the test in auto play that the sound changes in a buzz after a few houres.? I did this to see how stable it was and I have the same problems over and over again. after lets say 5 houres the sound disappears and I can only hear a buzz. I have to close the programm and start it up again.
geposted Sat 17 Dec 05 @ 8:09 am
Are you sure you are using the demo?
The buzz thing is an issue other users with cracked version have, because these versions have changed code and bugs. Other users have reported this problem with cracked versions only.
Please make sure you uninstall any "bad" versions before installing the legal demo.
geposted Sat 17 Dec 05 @ 8:18 am
