Hi there,
i'm using virtual dj 3.1 for the pc which works fine.
i'm using 2 soundcards...one for output to my speakers and one for output to my headphones....which works fine as well...
there's only one problem, when i matched beats in my headphone, and i mix in, the record i just matched with my headphones isn't matched when it comes out of the speakers...so my second soundcard gives some sort of delay...
is there any chance you know what it could be?
tnx in advance!
-Bas
tnx in advance!
-Bas
geposted Sat 17 Dec 05 @ 11:20 pm
BFiction,
Which sound cards do you have?, Virtual works fine with only one 4.1 soundcard (or better). Now we are in the version 3.2, the version you are using could give troubles.
geposted Sun 18 Dec 05 @ 8:03 pm
2 soundcards is not supported in the demo....
and i would not trust any cracked versions to give good results :)
geposted Sun 18 Dec 05 @ 8:48 pm
I use an onboard Soundmax card and a Creative Audigy PCI.
I use the 4.1 option of my Audigy right now.
but there are several reasons why i wanna use 2 soundcards:
-my headphones are now connected to the rear output of my Audigy, but the output volume is not loud enough.
-i want to record my mixes with third party software (soundforge)
when i record with soundforge it records both front and rear outputs! so the sound from my headphones is recorded too. i haven't found a way to record only the front.
logicaly, my onboard soundcard outputs the sound faster than the PCI card....
is there any way to sync them?
geposted Mon 19 Dec 05 @ 10:11 pm
like they said
2 soundcards not supported in demo
-gauge
-gauge
geposted Mon 19 Dec 05 @ 10:19 pm
I don't use the demo.
All functions of the 3.1 work perfectly.
but there seems to be a problem with my soundcards, not the program!
geposted Mon 19 Dec 05 @ 10:27 pm
contact e-service and explain your issues.
tell them what version you use etc.
they will take good care of you
-gauge
-gauge
geposted Mon 19 Dec 05 @ 10:31 pm
I can assure you, cracked versions of VirtualDJ will give you problems with the soundcards, and i wouldn't trust them as they could destroy your hardware.
geposted Mon 19 Dec 05 @ 10:51 pm
We have all the info you need already in the forums, but only register FULL users could look such info.
You have a lot of benefits with your purchase, believe me. You could have the lastest updates of the software, effects, samples and other forums too.
Is the best deal for the money you could have. If you don't believe us, look at the forum, there are many that come wihtout a license and with a lot of troubles... after doing their buy they are happy users!
geposted Tue 20 Dec 05 @ 6:15 am
