how do i create shortcuts for the three effects on each side?
geposted Sun 18 Dec 05 @ 9:43 am
go to shortcut settings, in Virtual DJ configuration.
You can make shortcuts for almost all features of Virtual DJ, very powerfull :)
geposted Sun 18 Dec 05 @ 5:13 pm
okay i went there and i don't understand it if you could like run me through a step by step or something because i don't understand it
geposted Tue 20 Dec 05 @ 12:10 pm
go into the keyboard shortcuts area of the settings in VDJ.
click add
press the key you want to use
then choose effects
then the effect selection
choose a value between 1 and 3
and which deck you want it on and if you want it momentary or not
-gauge
click add
then choose effects
-gauge
geposted Tue 20 Dec 05 @ 12:46 pm
