I just recorded a long set on Virtual DJ 3.01 and I noticed that after the recording file size got to (roughly) 2000mb it started counting BACKWARDS from 2000 as the set continued to record... I wasn's sure what this meant so I kept recording and the set ended up being almost 4 hours long, and now the wav file is corrupted!
What happened? Is there a limit to how long you can record a set on virtual dj? How can I fix this?
geposted Mon 19 Dec 05 @ 6:21 am
There is no limit, the limit is Windows, you cannot have a file greater than 2GB. To use mp3 decoder to record you must buy VirtualDJ here.
Good Luck!
geposted Tue 20 Dec 05 @ 10:42 pm
