Hi there,
i'm the owner of a Hercules DJ Control MP3 since a month.
It works great on my pc, except for some minor things...happy with it generally...
Now wanna use it with my laptop.
the problem is that my laptop only has one sound-output(which gives pretty crappy sound)
so if i want to use a hercules dj console, there's 2 options:
-Get a Dj Console MK2(with buld build in soundcard)
-Get a PCMCIA or FireWire soundcard for my laptop....
what whould you guys recommend?
-Bas
-Bas
geposted Mon 19 Dec 05 @ 10:24 pm
hercules dj console mk2
full version VDJ
and your all set
-gauge
full version VDJ
and your all set
-gauge
geposted Mon 19 Dec 05 @ 10:32 pm
BFiction, please modify your profile to enter your dj control mp3 serial number and the home version of Virtualdj 3.2 will be available.
If you have some problems this could be caused by the use of a cracked version.
I would recommend you to buy another soundcard instead of the djconsole mk2 because it would be something like 100$ waist, unless you want to have a new design and an integrated soundcard.
geposted Mon 19 Dec 05 @ 10:49 pm
I have the box and all the manuals in front of me, but where can i find the serial number?
i tried the number at the bottom of my console, but it says it's invalid.
So a new soundcard is better?
The advantage of an MK2 is that you can use it anywhere no matter what pc, notebook you are using right?
-Bas
-Bas
geposted Mon 19 Dec 05 @ 10:59 pm
Some DJConsole have this problem. Please contact your local dealer and they will give you the serial number.
geposted Tue 20 Dec 05 @ 6:30 am
