Is it possible to use the Mixman DX2 with Virtual DJ. If it is possible, which options do I need to set...?
geposted Thu 22 Apr 04 @ 12:59 pm
Yes it is possible.
You need to define/create Midi shortcuts to use it.
geposted Thu 22 Apr 04 @ 2:27 pm
Ahhh yes. That had totally slipped my mind.
Cheerz for helping me again.
geposted Thu 22 Apr 04 @ 2:28 pm
geposted Thu 22 Apr 04 @ 2:31 pm
Ive just looked and I cant find out how to define these short cuts?
I cant find anyting on the website or the manual to help me.
geposted Thu 22 Apr 04 @ 6:19 pm
Go to the option panel, -> open shortcuts, -> add, choose the action you want and just press the corresponding option.
I don't know if all will work or not.
PS: I may have use wrong words because I have a French version ;)
geposted Thu 22 Apr 04 @ 7:22 pm
... so it worked?? how about the scratch option??
geposted Fri 23 Apr 04 @ 6:30 am
