As I don't scratch very often, I'm wondering if there is a way to temporarily switch off the jogwheels on my DJConsole (perhaps using a shortcut key) or to reassign them so I can nudge the track with it, similar to the jogwheel function on the Pioneer CDJ500 etc.
Dan
Dan
geposted Thu 22 Dec 05 @ 10:16 am
Its easy -)
go to config->remote control
uncheck "use jogs to scratch" for dj console.
geposted Thu 22 Dec 05 @ 10:31 am
That's really too easy :-)
Thanx a lot !!!
Thanx a lot !!!
geposted Thu 22 Dec 05 @ 10:53 am
since it is in remote control tab there is no way to make keyboard shortcut is there?
-gauge
-gauge
geposted Thu 22 Dec 05 @ 1:22 pm
Try this good skin with the nudge / scratch buttons.
https://virtualdj.com/addons/skin.html?id=617
geposted Thu 22 Dec 05 @ 5:30 pm
@DJ_Gauge
- it's possible in skins (like Cioce says)
some skins have buttons that will change between nudge and scratch, that also works for the Console's behavior
geposted Thu 22 Dec 05 @ 5:35 pm
wow i thought of that but didnt think that it would change the jogwheels, only the mouse but thanks, its worth a shot.
-gauge
-gauge
geposted Thu 22 Dec 05 @ 5:41 pm
it works fine :)
But only SOME skins have this implemented.. other only change for mouse, as you say
geposted Thu 22 Dec 05 @ 6:59 pm
