Hi!
I have a big Problem with the Hercules DJ Console MK2. All Updates are done. The Crossfader doesn't work fine. If I turn it to the left side, Virtual DJ looks like this (look at the Crossfader)
http://img273.imageshack.us/img273/8091/crossfaderleft3qu.jpg
Mid Position:
http://img273.imageshack.us/img273/2716/crossfadermid5bi.jpg
Right Position:
http://img273.imageshack.us/img273/614/crossfaderright6yr.jpg
As you can see, if I put the Crossfader on the DJ Console to the left side, VirtualDJ only put it a litte bit over the middle ... and so on. Can you help me? Can anybody help me. I didn't find something in the forum. Sorry for my bad english.
THX
Mid Position:
Right Position:
THX
geposted Thu 22 Dec 05 @ 7:06 pm
Hi Zyphlix,
Unfortunately it looks to me like you have a defective unit where the crossfader is not calibrated right. I think you should bring it back quick for an exchange to the place where you bought it, or contact Hercules support.
Nicolas
Nicolas
geposted Thu 22 Dec 05 @ 7:52 pm
update the hercules drivers
www.hercules.com
New drivers for Virtual DJ 3.2 and firmware update available.
It might fix your device.
www.hercules.com
geposted Thu 22 Dec 05 @ 8:16 pm
