what if i want to use the console in asio mode.. can i say use tcv and not use it??
i have just asked my uncle in the states to place the order..
i am doing the right thing right\??
cheers
DJ Rudra
cheers
DJ Rudra
geposted Sat 31 Dec 05 @ 8:52 am
VirtualDJ 3.2 DJC Edition uses only the WDM mode (for what I have seen)
- VirtualDJ 3.1 Pro version can operate in ASIO, you don't need to care for it as VirtualDJ changes by itself the DJ Console MK2 mode from WDM to ASIO if needeed.
If you use another software than VirtualDJ, you choose the supported audio mode of DJC MK2 (in DJC MK2 control pane) before running the software. For example, to use DJ Console MK2 in ASIO with Ableton Live, you set DJ Console MK2 in ASIO in DJCMK2 panel first, and then you run Ableton Live.
geposted Wed 04 Jan 06 @ 5:37 pm
In fact VirtualDJ 3.2 DJC Edition uses the WDM mode when there is no use of external audio sources and Asio mode when using software EQ on the external audio source, but one doesn't see it, VirtualDJ changes by itself the DJ Console MK2 mode from WDM to ASIO if needeed.
geposted Wed 04 Jan 06 @ 6:10 pm
exactly...
And timecode only works for 5 mins in the console version, as a demo of the feature
geposted Thu 05 Jan 06 @ 1:42 am
