I was just wondering how to connect the hdjc mk2 to an external mixer. i have seen many posts on connecting the old console to mixer. but nothing to connect the new console also i will be using TCV so if anyone has all this already complete let me know please. plus i will be broadcasting so that changes the setup as well
-gauge
-gauge
geposted Fri 23 Dec 05 @ 9:04 am
Its a lot like the old console...
The MK2 have 2x stereo out (both mini-jack and phono/rca).
Connect each to a channel on the external mixer.
The MK2 have easy setup for both external mixer mode (crossfader can be disabled for console), and timecode use.
For timecode use , connect turntables and ground wire to the MK2 console (rca in, ground plug)
The sweet thing with the console is that it has MULIT use :
- pure mp3 mode (computer)
- pure timecode mode (where audio signal is used only to control vdj)
- bypass mode in hardware (where audio signal goes straight to mixer, for real vinyl)
- bypass mode in software (where softaware can be used to mix real vinyl)
geposted Fri 23 Dec 05 @ 3:28 pm
