How can i get Virtual Dj to activate a jingle with one touch without having to hold down the key (e.g. F6). I preferred atomixmp3's "one touch" jingle activation that allows you to touch F6 three times (and let go the key ) and hear the jingle execute 3 times (overlaping each other).
Is there a way i can get press my F keys rapidly (without holding them down ) to hear my jingles activate accordingly?
DJ L
DJ L
geposted Sat 24 Dec 05 @ 5:17 am
In VDj jingles do not overlap themselves. Each jingle can only be ON or OFF.
The default keyboard shortcuts for jingles work as follows:
- pressing (e.g.) F1 will start the jingle
- pressing F1 will stop the jingle if it's playing
You can also assign momenteral shortcuts (e.g. SHIFT+F1), which will play the jingle only while the key is pressed, than stop after release.
erXon
erXon
geposted Sun 25 Dec 05 @ 1:32 pm
i personaly prefer to turn the sample on and off with a button rather than have lots of samples that i cant stop all playing at the same time untill they finnish (or i go and turn the volume down with the mouse).
but if people want this it couldnt hurt, but i wouldnt use it........................
geposted Mon 26 Dec 05 @ 2:01 am
