Forum: Old versions
Topic: hercules djc loops
hi there... i was given a hercules dj controler a few days ago, the simple version (without the soundcard abilities) and i was wondering if it is possible to re-assign the loop controls. when pressing the no 1 button you get a 1 beat loop by default, the no 2 button is assigned to a 2 beat loop and the 3rd button controls a 4 beat loop. i want change this so i can have 8 or 16 beat loops when pressing the loop buttons on the dj control.
thanks
geposted Mon 26 Dec 05 @ 12:10 am
This is only possible with VDJ Professional Edition.
Unless you can remap the DJ control mp3 using midi shortcuts (shortcuts tab in VDJ settings).
how can i do that?
So how do you do it on the full registered VDJ?
Thanks,
Johan
Ok as promised, the new DJC Mapper v2.0 is available on this website
It's only compatible with VirtualDJ v3.3 and more !!!
screenshot:
virtualdj.com/blog/djcel/blog2107.html
