Hi Team !!
I have just purchased a Roland Juno-D synthisiser keyboard which has a Midi out on it. I also have a SB Live! which has a Midi I/O interface as well. By any chance, Can I use this keyboard with VDJ at all ?
I know this may seem like a silly question, but the only stupid questions are the ones that aren't asked ... Thanks !
geposted Thu 29 Dec 05 @ 4:47 am
You can use any controller that has midi output :)
Just connect it with sb live's midi/joystick port and make sure that controller has enabled midi out in settings. Than just enable the Midi under Settings > Remote control and map keyboard shortcuts with the controller :)
Regards.
Regards.
geposted Thu 29 Dec 05 @ 10:54 am
Trip,
Like Exron said, any MIDI controller can be used with VDJ.
In fact I have been considering using my Oxygen8 with VDJ, but haven't hooked it up yet. I would like to map some of the keys to samples, using the velocity as the volume. Not sure how this would work out, so if you get a chance, give it a try. I think it would be kool.
P.S. "The only stupid questions are the ones that aren't asked" ... well that's why they aren't asked, because they're stupid ;)
geposted Fri 30 Dec 05 @ 5:12 pm
