Forum: Old versions
Topic: how do I use this midi thing
Could someone please point me in the right driection on using a midi controller?
geposted Sat 24 Apr 04 @ 6:29 pm
Sure. Plug it in. Open your shortcuts. Select a shortcut you want to assign to a key. Hit the key and thats it ! Save your shortcut and re do this for each one you wish to add.
how are midi sliders programed???
Set this value on the midi slider shortcut value : 4098
0 = minimum
2049 = half
4098 = max
Does that work for jog dials too?
i don't think, try : auto for the jogwheel
