do any pro DJ's use the Hercules console MK2...what's your feeling on these..lots of lag?
or the XP10 or DAC3?
i'm leaning towards the xp10 pros suggest it
i gave up vinyl years ago
thanks all
thanks all
geposted Thu 29 Dec 05 @ 4:58 am
If you used vinyl before, I guess getting xp10 would be the best choice :)
NO lag, and good vinyl feel....
There is not lag using midi controller like hercules mk2 either (i use that), but it might not be all the "vinyl feel" to it, and maybe not as pro looking and feeling as the xp10
dac is more a rackmount think I guess... for the mobile dj
geposted Thu 29 Dec 05 @ 5:04 pm
