Hi
I realise that beatlock is frowned upon by my peers - but I mix with my feet and beatlock is useful to get initial alignment :)
I have noticed that the beatlock functionality in the new 3.2 versioon is off. It lines up the "blocks" that are suppose to correspond with the "peaks"/beats of the track but the new 3.2 version seems to be consistantly out by just under half a second.
Is there a new parameter that I have missed?
Does anyone have any ideas before I request a old version of VDJ? ;)
Cheers
Jon
Cheers
Jon
geposted Thu 29 Dec 05 @ 5:14 am
beatlock have been changed a bit
left-click on mouse = beatMATCH
right-click on mouse = beatLOCK (like before)
hope that helps:)
hope that helps:)
geposted Thu 29 Dec 05 @ 4:35 pm
thanks ....
Two questions:
- Where do I click?
- Is there an SDK command to enable/disable the old style of beatlock for each deck? - Thinking I may need to monkie with a skins :)
Cheers
Jon
Two questions:
- Where do I click?
Cheers
Jon
geposted Thu 29 Dec 05 @ 11:03 pm
when I said click, I meant in default skin... :) where the beatlock/beatmatch button is..
It migth be different in other skins, not sure.
if you LOCK (rightclick), then it is kinda like the old way. The deck that is NOT locked, controls the deck that is... Try moving pitch on the "free" deck, and the locked will follow.
geposted Fri 30 Dec 05 @ 12:42 am
Hey!
I found the answer ... I had autoBPM set to Smart. Toggling autoBPM to enabled has resulted in a far better alignment of wave-form peaks.
Cheers
Jon
Cheers
Jon
geposted Sun 01 Jan 06 @ 10:13 pm
