hi i have just bought a numark dxm01 USB mixer and have virtual d0j 2.05. the mixer is not currently working as two channels on the programe and i was wondering if you could tell me how to config the programe to make the mixer work as two channels to a computer.
geposted Thu 29 Dec 05 @ 9:47 pm
I can help you out with that problem :D
First in order to use your mixer you will need the full version of Virtual DJ pro which can be purchased @ virtualdj.com/purchase
Second once you have the latest version of the software we'll help you out with support :D
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Thu 29 Dec 05 @ 11:43 pm
Btw. Matt I also have this mixer and it works smoothly for me ...
I will gladly help you when you solve the issue mentioned above by WhiteDVL
geposted Sat 31 Dec 05 @ 1:04 am
