Ive been checkin throughout the forumns if there has been a topic focusing on downloading effects. Sumhow im having problems..... Whenever i try downloading an effect that is not .exe or .zip it automaically brings up a box that lets me choose the program i want to open it with, ive already chose winzip and winrar but it doesnt seem to work. ive also tried putting the downloaded effect to the VDJ Effects folder and still it doesnt seem to work. Note im only having problems with a couple of them (the ones dat are not .exe/.zip) such as 'Flanged LoopOut', 'ECHO V2.01', 'Back loop', 'Phase Shifter', LoopOut V2.01', '32-Band Equalizer', and couple of others. Is there a program for it extract the effect? Any tips are appreciated.
Peace
Peace
geposted Thu 29 Dec 05 @ 9:49 pm
ALL effects are EXE files...
if the dont download as exe files, try right-click, and choose "save-as"
Or, simply rename the downloaded file to EXE extention.
Seems some brownsers have issues with downloading from this website.
geposted Fri 30 Dec 05 @ 12:39 am
yo man thx. i appreciated, it worked!
peace
peace
geposted Fri 30 Dec 05 @ 8:47 am
