Hi Everyone
I have a question in regards to the video in vdj. what is the best spec for a computer to run the video portion of the software nice and smoothly. with out any stuttering or freezing.
geposted Fri 30 Dec 05 @ 10:50 pm
The best specs would be:
Processor: Pentium 4, 3Ghz or equivalent in AMD configuration.
RAM: at least 1Gbyte
Video Card: 128 MB or 256MB non-shared memory Video Card, with at least an S-Video Output and the possibility to use double screen output, one for VDJ, and one for the video on another screen.
geposted Sat 31 Dec 05 @ 11:26 am
You could check this:
https://virtualdj.com/forums/41042/Hardware_Technical_Support/Video_card_Info.html
I recomend this video card: http://www.newegg.com/Product/Product.asp?Item=N82E16814125175
geposted Sun 08 Jan 06 @ 6:40 am
definatley 1 gig of ram at least , 2 even better!
geposted Sat 06 May 06 @ 1:50 am
i tryed with 4GB of ram, but i didn't notice the difference when i was using 2GB. just for info...
geposted Sat 06 May 06 @ 10:46 am
when vista comes out and can support 8 gig + things are going to get better and better:)
geposted Sun 07 May 06 @ 11:06 pm
i think that if VDJ will be for mac i won't use vista ;)
geposted Mon 08 May 06 @ 1:11 pm
Besides having a good cpu and 1-2 GB of memory, the best insurance for smooth video is a fast hard drive. If the hard drive can't deliver the content fast enough, the video will suffer. I use a 4 disk RAID-0 and have not had any issues.
geposted Thu 11 May 06 @ 5:36 am
4 discs in raid0????? actually you don't need such a speed :D and what if 1 disc failed? you will lose all data.
At home in desktop pc i have 4 discs of 300GB, 2 of them are in raid 0, 2 are in raid 1
geposted Thu 11 May 06 @ 9:57 am
I drop in the backup RAID should a failure occur. The drive that I use are RAID edition, which are designed for high vibration environments.
geposted Fri 12 May 06 @ 6:10 am
I think it will be better to use RAID 0+1 with 4 Hard disks... you have high bandwitht and speed and also a mirroring arrange.
geposted Fri 19 May 06 @ 8:23 am
I have a Raid 0 set up with a backup drive, ad a store drive.
I agree with acw, when i get chance, ill get 2 more and raid 1 them, so i have fault tolerence as well as speed.
geposted Fri 19 May 06 @ 11:18 am
Everyone has an opinion of how to best setup their computer. There is no difference between my RAID 0 setup and someone using a laptop with a single hard drive. The only major difference is speed and the reliability of the RAID edition hard drives that I use and the hot swapping capability of my drives. I have backups for both the operating system and my music.
geposted Tue 23 May 06 @ 4:31 am
