Forum: Old versions
Topic: Hercules DJ Console MK2 in the UK?
Does anyone know where I can purchase an HDJC MK2 shipped to Europe? I've looked in shops and only seen the original models and also looking online doesn't seem to have helped. Amazon UK seem to be the cheapest place with the unit costing £144 although they don't have a date which they expect to have stock. Similarly, all other retailers appear to be out of stock until January sometime. Has the unit had an official UK release? Also what are the restrictions of VDJ3 from the Hercules unit compared to the professional version purchased from this site?
Thanks, Andrew.
geposted Sun 01 Jan 06 @ 3:30 am
Hi There,
It is avaliable in the UK this minute but there aren't so many that people are shouting about it, avalaible here and numerous other places: http://www.pixmania-pro.co.uk/uk/uk/144758/art/hercules/dj-console-mk2-sound-card.html?srcid=867
For a list of the differences between the free console version and the proffesional version please read here: https://virtualdj.com/products/djcedition.html
Kind Regards, Bagpuss.
p.s please overlook a few of the minor spelling mistakes, they are being corrected ASAP.
Thanks for the reply, unfortunately that website also does not have stock. I ordered the console from Amazon earlier this morning despite them not having stock and their product page only containing a model number (4780393 - no description yet).
Hopefully I will receive the correct equipment when they have stock and they won't charge me more; the original DJ Console sells for just over £160 at Amazon and I've ordered the MK2 at £145, I'll let you know how it works out.
As DJ Console MK2 distributor for the UK is Etcetera, Etcetera probably can tell your where you can find the console.
You could always try dabs.com. I got my original console from there, and it was pretty good service. I *think* they have some in stock atm too
Nebula
I used them too, very good, highly recomended.
Thanks for the replies I've checked out all the mentioned sites. Dabs has no stock and my usual computer store (eBuyer) don't even list the MK2. Etcetera are charging £180 for the MK2 although it does not state if they have stock, personally I'd rather wait two weeks to receive the MK2 from Amazon as I've already spent the £35 difference on TCV :)/
OK, i'm not sad or anything, but i'm lookin' at a mk2 myself, so I though why not share the results. I did a google search and found these sites:
dv247: I'm not sure about stock status
http://www.dv247.com/invt/30596?source=google&campaign=uk&ad=30596
Pixmania: Out of stock tho :o(
http://www.pixmania.co.uk/uk/uk/163563/art/hercules/dj-console-mk2-sound-card.html
DJ Store: Stock expected 10-14 days and £180 (bit much methinks. mebbe if one was available now...)
http://www.djstore.co.uk/cgi-bin/item.pl?item=herdjconsole2pc
Amato : £155, not sure about stock status
http://www.amatodistribution.co.uk/DJ/Product/?productID=5749
NUSusyems: £155, again not sure about stock status
http://www.nusystems.co.uk/product/Hercules.DJ.Console.Mk2
If your not in any immediate hurry, i'd use www.Dabs.com purely because of past experience with them. none of the above sites have stock in and prices range. It's your call though.
Happy Mixing
