I have tcvs and a u46dj, vdj 3.2 pro. The time code quality on each deck is all over the place and inconsistent, therefore the program does not function without messing up and skipping parts of the songs. I have stanton st 100 tables and stanton trackmaster rs cartridges ... if it makes any difference. What could be causing this instability? When I plug an mp3 tccd line into the turntable, vdj reads it at 100 percent.
geposted Mon 02 Jan 06 @ 6:37 am
are you saying you put in a cd deck and get 100% with no trouble? Do you have the Turntables grounded to the laptop/pc case? If they are then i'm not sure but mine also does a funny thing, at about the last 2 min on the vinyl the % is just all over the place but never causing a skip and when i drop the needle on the start again it 100%, i was told it was needle calibration but i tried a lot and no luck. See what your do, maybe it is your needles need adjusting
geposted Mon 02 Jan 06 @ 7:43 am
