i'm looking to download skins but i cant find the skin folder on my HD. I know it should be in C; PROGRAM FILES/VIRTUALDJ or AUTOMIX/SKINS but i dont have any dj folder in my program files. thanks
geposted Mon 02 Jan 06 @ 5:18 pm
Where is the software installed ??
geposted Mon 02 Jan 06 @ 7:20 pm
i installed the software by cd but cant find where it was installed too. i done a search but no hits.
geposted Tue 03 Jan 06 @ 4:12 am
right-click the icon on your desktop where you start the program, and choose "properties"
You should be able to read where it is installed there
geposted Tue 03 Jan 06 @ 7:08 am
As Norway said it should work. If not try opening up my computer. Then click program files. There you should be able to find where it is.
geposted Wed 04 Jan 06 @ 5:43 pm
