Is vdj compatible with m-audio delta 1010 ? Because of the 8 outputs of this soundcard should i go to advanced settings or 5.1 soundcard? I have an external mixer. I don't have the delta 1010 yet, I want to buy it and I want to be sure that is compatible with Virtual Dj.
geposted Tue 03 Jan 06 @ 6:40 pm
yes the delta 1010 is fully compatable, either use the advanced setup or the tcv setup if you are using tcv.
geposted Wed 04 Jan 06 @ 1:45 am
thanks for the answer
geposted Thu 05 Jan 06 @ 8:17 pm
Does the Delta 1010LT rock solid even with a low latency?
And is it possible to connect the TCV Turntables to channel 3, 4, 5, 6 due to the XLR inputs on 1 and 2?
Thanks alot 105db
Thanks alot 105db
geposted Mon 03 Apr 06 @ 10:33 am
My system was built with a 1010lt and I love the flexability I now have over the specs on a maya 44.
I have not (yet) set it up with TCCD but that is one of my goals. I can't wait to set it up with my reliable Pioneer 500 system.
It amazing how sophisticated the 1010lt is.
geposted Wed 12 Apr 06 @ 5:18 pm
M-Audio 1010 It's compatible with VDJ. But even you can use only a M-Audio Delta 44 PCI and use VDJ and TCVs or TCCDs. Of course it's better to get VDJ Pro to get all VDJ funtionality.
Good Luck!
geposted Tue 18 Apr 06 @ 5:48 pm
105,
Yes it has a patch bay that would allow you to use any input line and assign it to where you need it in the patch panel window
geposted Wed 19 Apr 06 @ 6:36 pm
does anyone know how to route the tables for the tcv with the delta 1010lt???? i can get one table to work but not both!!!! in 1/2 are xlr.....so i started in with in3/4 but vdj in the input select does not give the option to choose anything other then in1/2 & in3/4 right or in3/4 & in1/2 left. so do i use the xlr in1/2 or what is the proper way to connect????????????????????????????????????????????/
geposted Fri 28 Apr 06 @ 9:42 pm
i did figure out something..in the time coded menu......it only shows a m-audi ASIO but in the other choices for sound card it shows the m-audio delta 1010lt.....why does it do this?? why does it not show the same thing i all the selections for sound card
geposted Sat 29 Apr 06 @ 1:34 am
