what i need 2 know is does any body here use this software in a club,and what pc/s,screen/s soundcds/s,s do us use,what would be a rock solid setup starting off a 2800 amd ,and will be portable in holdall bag for transit to clubs ,NO notepads not enough steam ,i hav to run visuals aswell,does ne one here do this both ? on 1 pc?
geposted Tue 27 Apr 04 @ 7:46 pm
ehm i think you will have to wait for Pentium 9 to come out.
till then.. use 2 pc's dude.
i use a Hercules DJconsole on a well tuned AMD-2400 1 GB-ram. I had some problems, but they are all solved.
geposted Thu 29 Apr 04 @ 5:33 am
Use Xp-Lite www.xplite.com
You'll certainly need a separate monitor as Coyote do, if I remember well. This way you can do both with only one computer.
FRUiT94
FRUiT94
geposted Thu 29 Apr 04 @ 11:48 am
hmm.. you might be able make both work on 1 single pc if you use xp-lite, but i still would not recommand that as it is demanding a LOT of resources from your pc, which could easily result in a unstable machine.
geposted Tue 04 May 04 @ 8:50 am
