Is it possible to have both the KP2 and DJ Console connected in a simple set up- just to my pc?- can't seem to find any info on this, so any help would be appreciated.
geposted Thu 05 Jan 06 @ 12:45 pm
no it isn't possible to do it, because the KP2 is to use with a real mixer, with effect send & return signals.
geposted Thu 05 Jan 06 @ 1:12 pm
However, if you are thinking of using the Kaoss Pad as a MIDI controller, then the answer is yes.
geposted Fri 06 Jan 06 @ 3:11 pm
How would I set it up as a midi controller- would it still work as an effects processor?
(sorry, don't really know much about all this yet)
geposted Fri 06 Jan 06 @ 8:13 pm
You could use it as both at the same time, but anything you do with it as an effects processor will still be seen as a MIDI event and VDJ would still react to that. I guess you could disconnect the MIDI cable to disble the MIDI events, or build a simple switch to virtually connect and disconnect the cable.
geposted Tue 10 Jan 06 @ 7:07 pm
